Set of gaskets automatic transmission 0BH 0BT DQ500 DSG 7 11-up
maktrans.net
Not the same as for Transporter.I realise that this is not the crafter section. However, I am considering buy a higher mileage auto/dsg crafter. It does not seem to have had any gearbox services. Are the intervals the same for the crafter gearbox please?
My van is due for its 60,000km DSG fluid change, and in the process of getting the correct oil and filter.Think this is the one I fitted but double check
Correct oil is no issue, but getting conflicting information on the filter. The above one is what I used when I did the service on my Audi Q3 DQ500, but part number OGC 325183 A is stated to use on the T6 DQ500 DSG....
Genuine VAG DQ500 DSG Gearbox Oil Filter - T5 / T6 Transporters Only! - 0GC325183A
DQ500 Oil Filter, Transporter Models Only!www.akstuning.co.uk
Looking further it looks like they are both the same size, so curious to difference?
I have asked AKS tuning, so will see what they come back with.Is it the micron rating?
This is a youtube clip of a DSG DQ500 fluid change.:Just had the oil changed on my T6.1 2022 150hp VLD code DQ500 gearbox and the following parts were used
Filter=OGC325183D
O ring=N91084501
Washer=N0138132
Washer=N0438092
Oil=G052182A2
