A weird one here. All other lights working, front back and interior, but driver side stop light not. Have replaced bulb, but tbh the original one looked ok. Any suggestions / similar experiences?
My only suggestion would be to take off the lamp cluster (2 screws) unplug the cable harness, find out which is the brake light pin in the plug (or socket) by elimination and test if there is a voltage there with a multi meter or voltage tester. Use a helper to press the brake pedal on and off while the ignition is on. If the voltage is there then it's the cluster wiring, maybe a bad bulb socket connection. If no voltage then its a problem further back up the wiring loom. Test a side light or indicator to check you are getting a good connection before trying the indicator. Good luck.
