DIY Puncture Repair Kit. . . . . . . .
Dellmassive
VCDS User
Moderator
T6 Master
DIY Puncture repair kit. . . . . . . .
two punctures to repair today . . . . . . a screw and a nail in each of the rear tyres
Using these kits have saved me a fortune in £10 puncture repairs . . .
Heavy Duty Tyre Puncture Repair Kit - https://amzn.to/36RQ16S
VAN TYRE PUNCTURE REPAIR KIT - https://amzn.to/2twZSjX
Holts Tyreweld 500ml - Holts Tyreweld 500ml: Holts: Amazon.co.uk: Car & Motorbike
T-MAX 12V Air Compressor – BA2641 - T-MAX 12V Air Compressor 4x4 Off Road Tyre Pump Car Van Truck - BA2641: Amazon.co.uk: Car & Motorbike
Heavy Duty Air Compressor 160L per MIN - https://amzn.to/38Sua0N
Ring RAC635 Preset Digital Tyre Inflator - https://amzn.to/34zHMKT
now for the video:
BLOXSPORT M14x1.5 Wheel Hangers - https://amzn.to/3b8jpYQ
More info over here > Dellmassive`s -- "how I Done It" -- Thread
Just had a set of michelin pilot sport tyres fitted to my wolfrace assassin wheels only 2 weeks ago, day before yesterday i pulled out of a gravel car park and o/s/f tyre flat as a witches tit. Was told by my local tyre company that it was unrepairable so i gave it to ATS who said they would send it off to see if it could be heat welded but they were not sure as although the split which was actually right in the centre of the tyre didn't look too promising as it was approx 25mm across in length.
Lol.. all comments and suggestions welcome. :thumbsup:
Give me an idea for some music that I could use... artists, bands or genres..... and I'll change it up on the next one.
(FYI . .. . Anything but that. Doesn't help)
people have been asking about the Wheel Hanger studs . . . so here they are.
BLOXSPORT M14x1.5 Wheel Hanger - BLOXSPORT M14x1.5 1 pair Wheel Hanger Wheel Lug Bolt Guide Automotive Mechanic Tool for Audi VW Porschse: Amazon.co.uk: Car & Motorbike
I've also added them to the list now.
Kit List And Stuff -- How I Done It & What I Use --
OMG, will please stop putting things like this up. Its costing me a fortune :eek::eek::eek:
LOL, . . . there in the video i done above.
A VW Master tech mechanic put me onto them....
helps fitting heavy wheels on a car/van when its up on a lift.
they take the weight, so you can line up the wheel bolts easier...
I think they are great. . . . . you can use one or two
@Dellmassive ...just thought of a great sound track to go with your video......Al Green..I’m so tired of being alone....
I've got bad ears ...sounds a bit flat to me :whistle:
if its not copyrighted i can use it for YT vids . . . . . . great bit of soul that.
New Tyres time . . . . . Front's.
Check out these Beefy Chunkers . . . .
bit more expensive that the last ones, £86 each fitted. (i only go for budget tyres)
lets see how the Callipers are doing . .
these are the tyres . . .
20201107_100004.jpg20201107_100838.jpg20201107_100900.jpg20201107_100935.jpg20201107_104136.jpg
Check out they Beefy Chunkers . . . .
View attachment 90949View attachment 90950
View attachment 90951View attachment 90952
View attachment 90953View attachment 90954
View attachment 90955View attachment 90956View attachment 90957View attachment 90958View attachment 90959
Nice....I’m about to change mine for all season....gets embarrassing when I need pushing on wet grass:(
Anything but Sam Smyth! He/she/they irritate me more!
I work closely with Goodyear and on some of their tyres they permitted repairs to the actual sidewalk not that I would purely as it’s out of the norm
In my experience most tyre depots are more likely to try to push a normal customer toward buying new tyres rather than a repair, unless you (as in your case) you have enough professional expertise to stand your ground.
British Standard Tyre Repair Rules
  • Tyre repairs for cars and vans are only permitted in the central 60% to 70% of the tyres nominal width (known as ‘Area T’), with this percentage differing as shown below, depending on the size of the tyre.
Repairable Percentage Area (‘Area T’) based on Nominal Section Width​
Up to and including 155mm
60%​
Between 155mm and 200mm
65%​
Above 200mm
70%​
Example - Tyre size 205/55R16;
Nominal section width = 205mm
70% of this width = 144mm
This tyre is repairable within 72mm of either side of the tyre centre line.
  • The maximum diameter of the penetration hole left by the puncturing object is 6mm.
  • Repairs in Area T must not overlap one another.
NOTE: All the information on this page is relevant to what is considered a minor repair to a radial construction tyre fitted to a car and van. This information is not relevant to commercial vehicles, heavy plant or industrial vehicles. Major repairs such a repairs to sidewall damage are also governed by the same British standard but will need to be sent away to a specialist major repairer.
I carry out puncture repairs and to vehicles that do well over the 100mph mark our procedure has been tested, a lot of tyre places don’t have the skill set to repair
Reactions: JOG
