Disconnecting A Battery.
Nightmare
I have a 2017 T6. I am going to disconnect the battery for around a day while I wiring a split charge system. Will this prove to be a problem for the radio? Or will this lead to fault codes appearing on the dash?
Also is there an ignition live cable or feed under the passenger twin seat? If yes do you know the colour code for where a a split charge system can be wired in?
It’s a ctek 250 split charge.
Try and limit total disconnection time to less than 8 hours otherwise component protection will kick in on the radio.
