Detach and re-attach same head unit in t6.1
scrapi
Hi,
I'm just replacing the heater linkage (since it broke).
To assist with access I have removed some of the dash and was planning to take the stereo head unit out - Hence the question...if i disconnect the head unit and re-attach it the next day - will it need a "code" to re-access the stereo when i switch it on? I remember the older car radios needing a code every time they got disconnected.
THanks.
No nothing like that, the headunit is coded to the van so no issues disconnecting battery or the headunit everythign will just work when reconnected
