Dc to dc charger victron or renogy?
T6.1 slayer
Can't decide between the 2 does the renogy give out 50a charge ? I've read all the stuff about solar and alternator connected at same time and isolators to trick into just one is connected but is there still a 50a charge ? Bit lost in the flood of Chinese wires and panels ? Hoping to use 100ah lifepo4 renogy self heating and mainly only want the renogy 50a unit as my alternator charger . Any guidance appreciated
Renogy Dc50s will charge at 50A from Alternator alone.
Then get a seperate Victron mppt for solar. (75/15 smart)
The sweet spot for charging lifepo4 is C/3 where "C" is the capacity of the battery, so for a 100Ah battery, the ideal charging current is a shade over 30A. This will give maximum battery cell life. The 50A Renogy will be ok, but "might" stress the battery. just something to consider. You could go the whole Victron route & have an Orion 12/30 & the Bluesmart MPPT that @Dellmassive mentioned. As an aside, I've gone through a CTEK DC/DC/solar charger & A Sterling B1230, I'm now a fully paid up member of Team Victron. The victron kit has been faultless.
My insight on the CTEK
250SE. I have one, it's performance is flaky/poor and CTEK have not been the slightest bit interested.
Similar to my experience. The CTEK eventually died & I just binned it.
Thanks for the info, and that rules ctek out , is there any other battery that is better in price than renogy 100ah self heating? Will probably go full victron on that advice as I don't want anything fan cooled anyway, but if anyone thinks I can improve on battery for money I'm all ears ? I understand sort of that putting too much amps into battery can reduce life but will have fridge freezer running from moment I drive so maybe sort of compensation for extra amps? If not can it be throttled down so to speak ?
I've ordered the victron orion, the mptt controller will the 75/ 15 with Bluetooth is that the one and will that do 200w of panels if required?
I've had no issues with my Redarc BCDC1240D, 40A alternator and built in solar charge controller (up to 32V) which works with my 200W panel.
Now that throws a spanner in the works ? Has to be air cooled no fans
Purely a personal opinion, but having been bitten by the Ctek, I now prefer separate components rather than “all in one” solutions. Fault finding is easier & if one bit fails, you’re not swapping out the whole unit. Also you get a certain amount of redundancy with separate units. E.g. If the solar fails, you can still use the DC/DC & vice-versa.
Like I said, it’s purely the way I look at things.
I think I have to agree separate components just better starting off on the right foot ? What about battery anything better on market than renogy? Also you seem to have been down the route of buying other models that haven't made the grade example ctek and it boils my wee when give hard earned cash over for a substandard product.
The Victron Orion runs very hot and may need forced cooling.
You can program the current limiter on the Renogy dcc50s.... So you can set it at 30A if you wished...
I show the Orion,CTEK, Renogy, Redarc over here.....
See here ..
Roamer.
So I can adjust charge on the fly with app so if I'd ran battery to 60% but only driving for a couple of hours I could 50 amp it and use accordingly
Yes. With the Renogy dcc50s and the bt2 adapter and the Renogy home app .
You cant do this with any other DC-DC chargers AFAIK.
(I'm running this combo in the van now)
Running charger @ 30A on a Renogy 100ah lifepo4.
Screenshot_20220816-073342_DC Home.jpgScreenshot_20220816-073332_DC Home.jpgScreenshot_20220816-073326_DC Home.jpgScreenshot_20220816-073319_DC Home.jpgScreenshot_20220816-073306_DC Home.jpgScreenshot_20220816-073256_DC Home.jpgScreenshot_20220816-073241_DC Home.jpg
@Dellmassive yes that seems such a useful feature to toggle amps as you please ? I've actually spent hours watching your builds but I'm not electric minded to a degree? So sometimes difficult to grasp but the solar panel comparison definitely gave me a better understanding of panels ? Another question why do you use a shunt when you can view everything on app is it accuracy?
Yes. Most lifepo4 BMS don't register loads below 500mA, so the soc reading will drift over time.
Fully charging the battery will reset the drift.
But I'm a geek and need to know exactly what's going on.
So I run the Victron smart shunt as it's very accurate.
All good... I have had warranty kit replacements and good coms from technical.
They are China based so normally reply over night or the following day.
They have local UK stock warehouse and also sell on Amazon,.... So kit is normally fast delivery.
No issues as long as you buy from them, either directly from there UK website or there UK Amazon shop.
