I want to do the same . They look gooddoes anyone know how easy it is to fit daytime running lights, from vw?
Yes all in the kitIs all this on the retrofit kit @Pauly?
Don't change anything on the existing setup although the original DRLs can be disabled with VCDS if requiredThis may be a silly question. I too was thinking about adding the led grill mounted DRLs. How does this effect the regular DRLs mounted in the lamp units? Do the work aswell or are they deactivated? May be obvious but not sure! Cheers
That is the correct part numberNot sure if this is a help but I think the Part Number for the DRLs from VW is ZGB7E0052192
@Paul, I completely agree, the yellow tones when you ordered up LED headlights seem to me to be a cost saving NASTY from VW, especially when you pay premium for LED headlights.
How did you go about reprogramming the fog lights?
Interesting argument here is that fog lights in the UK are a technical illegal, conflicting terms of use on the highway code and UK laws ( I was told by a friend)
