CXHA engine wet. Are the injectors or breather leaking? Moisture, wet at the end of the first cylinder of the engine. Should I be concerned? The car still has 22 months left on the warranty.
Hopefully the dealer can answer this for you once they've examined/repaired it. Sadly we can only guess from afar.
Whether it is anything to worry about is also open to question. We can be sure it wont get any bettercon its own, and will likely worsen, so it would be prudent to get it sorted, particularly as it's a warranty problem.
Best of luck, let us know what it turns out to be.
