Ctek Smartpass 120 or other solution?
Alanmh
I have a 110Ah leisure battery and a Ctek D250SA, also a 150W solar panel, however on a run of dull days the battery can get pulled a bit low by the fridge that can pull 4 - 6 Amps.
I dont want to go to LiFeP04 yet, as its just not cost effective.
I guess the choice is:
1) Get a Ctek Smartpass 120 so the battery charges faster from the engine or a replacement leisure battery.
2) Get a better battery - maybe AGM?
3) Get a bigger solar panel
Any ideas / comments on the options?
Thanks in advance
Alan
4-6A for the fridge . . . . ?
what fridges is it?
got any pics?
POWER:
Dellmassive`s -- "how I Done It" -- Thread
Kit List And Stuff -- How I Done It & What I Use --
compressor fridge then,
once its down to temp those power usage numbers should drop . . . .
Not domestic Dometic. Yes. They do, quite a bit. My test was on a hot day with the fridge empty, so I might be being a little harsh on it. Will find out next week after a rainy week in Devon with no Hook up!
well from your OP at top. . . .
id say if you have 150w solar . .
its about 6A per 100W (ISC) to 9A (ISC) max.
then if Lifpoe is not your thing then look at swapping out the SLA battery for a AGM . .
start there . . . .
you could add more Mobile solar . . . .
you could look at Lifpo4 (expensive upfront but cheaper in the long run)
you mentioned about a smart pass. . . . . but the 20A ctek is about the limit for 1x AGM 100ah battery anyway, so might not help much.
the 4th option is to just double up and add either a second battery and run in parrallel . . . . or just take a second battery and swap out once the first is flat . . . .
also look at some battery monitoring . . .
Thanks @Dellmassive the ctek is pretty fussy about Voc as you know, but I will take a look at your panels thread.
I got a smart shunt after reading your battery monitoring thread, which kind of identified the problem.
Spot on about the smartpass, I guess that was my real question.
Why does agm do so well? What are the advantages?
Just read your mobile solar panel thread @Dellmassive, and remembered that I have a 100watt folding rigid panel in the garage.
It has a pwm controller with the 2 x 50W panels in parallel. Voc is good for the ctek. But how best to connect?
1. Connection from pwm to ctek solar?
2. Bypass pwm and connect to ctek solar?
you can do either . . .
start by adding it in with your existing 100w panel . .
so existing 100W + (50W + 50W) = 200W
in parallel the VOC will stay low, but the currents will addup.
but also note the weakest link as mentioned in my mobile solar post . . .
monitor the charge rate into your leisure system with your BMV battery monitor . . .
run it for 10mins and note the power . . . .
next disconnect the panels and connect to the included PWM and connect back into the Leisure battery system
use a body ground for the 0v so you dont bridge the BMV current shunt . . .
Again use your BMV to monitor the charge rate,
this time it will be the existing panels with the ctek mppt + the mobile PWM.
ill assume the ctek mppt will give you the most yeild - depending on the existing panel spec you have and how different all the panels and VOC/ISC ratings are . .
post your results back here . . . .
some more pics will help . . .
AGM is a massive improvement over standard SLA deep cycle batterys
thats why all stop/start cars have them over SLA batterys.
AGM has higher energy density, faster recharge, less volt drop under load etc etc . . .
you can see the effects over here when i started drawing 30A from a 2x100ah SLA battery bank . . .
AGM is far superior..
they also have a higher rest voltage . . . .
defo worth starting with a decent battery,
I've got two of these . . . . (they fit under the seat standing up too)
Looks like I would get a much better return on buying 2 of those than anything else! And actually not that much more that a smartpass and much cheaper than lifepo4.
I'll have a play with the 2 connection methods. The Victron will show me the difference nicely.
Not sure I will have or stable sun before we go though.
two of those will give you a 220ah total.
Being AGM and subject to a usable 50% DOD Capacity you have to half it,
so 110ah uasable . . . .
so that 2x batterys at £160 each. @ £320
£320 divided by the 110ah usable amp hours = £2.9 per ah battery capacity.
dont for get lifpo4 has 100% DOD . . . .
so 1x lithium 100ah is equivalent to 2x100ah AGM`s
but agreed your still looking at £600 £700 for a new 100ah Lifpo4.
Stay away from the Smartpass. It will not give you what you are looking for and could damage your leisure battery. I agree with Del, go for AGM for better performance.
Thanks @travelvolts. I admit it was niggling at the back of my brain that charging at 120 amps can't be good. And probably not achievable. Where would it come from? Can't be good for starter battery or alternator.
Can you do next day delivery for a Saturday?
