could i feed 2x 12v 6 way fuse blocks from a main 12 way 12v block to reduce cables?
winstonedd
my thinking is 12 way 12v fuse block will be the main block but two of those feeds can go to seperate 6 way blocks that can be placed in different parts of van.
any help would be great
I guess the 12 way block would have a larger (midi?) fuse at the battery end? This would mean some of your gear is fed via 3 fuses in series.
Distributing the fuse blocks is a good idea, but my preference would be to fit 3xMidi type fuses at the source/battery end, and feed each fuse block from these. Make sure to rate the cables to allow for loads that you may fit in future.
