Cluster 32-pin connector data
As promised a bit of overall explanation.
@Daku's controller can be installed in 2 different ways.
1. Externally to Instrument Cluster(effectively behind the IC)
This is definitely preferred way for less advanced users.
In this setup controller serves its functionality via CAN-BUS only
and available functionality is as follows:
- DPF regeneration indication via: LED, gong & text message
- additional Bluetooth icon
- engine & BCM data via AUDIO menu screen
- gear shift suggestion (not required for T6 engines)
- more to come
With this option the controller comes pre-wired with crimped connectors and appropriate plug/socket setup.
Basically 4 required wires need to be un-clipped from Instrument Cluster plug
and re-populated with provided ones.
+12V (red by @Daku) --> pin 31 (black by VW)
GND (black by @Daku ) --> pin 16 (brown by VW)
CAN-H (yellow by @Daku) --> pin 28 (orange/purple by VW)
CAN-L (brown by @Daku) --> pin 29 (orange/brown by VW)
Literally plug&play.
This is non invasive wiring methodology and can be reverted with no trace at any stage.
Installation example below.
View attachment 143581View attachment 143582View attachment 143583View attachment 143584View attachment 143585View attachment 143586View attachment 143587View attachment 143588View attachment 143589View attachment 143590
2. Inside of Instrument Cluster for more advanced users.
Controller serves its functionality via CAN-BUS(as described above)
and also allows to control FRONT ASSIST & SIDE ASSIST LEDs(both green ones).
Chuffinghell Robert what a thread thankyou very mutch ( mainly needed as I’m refining wireing from the t5.1 cluster )(which is in a t6 shell ). Now fitted rsq3 cluster into t6. Hopefully more compatible with rest of conversion
Mainly just for the cluster so key just sees cluster as my speedo gauge stopped working on my others ( stilling abs wheel speed and if I go into vcds it will move the speedo gauge
I am not sure what you are asking for.
Are you trying to transfer immo data to your "new" Instrument cluster?
Sorry as my currant cluster has a speed problem ( stopped working )
I plugged another set of clocks in and speedo works , so can a new immo ( key chip be programmed on the beach ,
Yes it can but you'll need ODIS or some other fairly expensive kit to do it. Nothing VCDS or VCP can do.
Your not miles away your locations says Yorkshire. Put your old clocks in book it in bring it down we can sort it no drama
Can u do a immo chip just for cluster. I don’t mind a drive
