Hi,
It was the £94.99 one from Vanstyle, although I bought it via their flea-bay store as it was cheaper.
The 'swage' is knock on trim.
My van has 40mm lowering springs, so I had to raise the van front a bit, to get drill clearance. I even ground a drill down to length to make it easier. Access to the bolts is easy if you take out the fog light insert in the wheel tub. The middle ones are tricky but can be done without taking off the big plastic under tray.
I sourced some M6 penny washers, ro spread the load more on the plastic.
Looks okay, subtle and a bit different.
