So I've got a camper with a Clayton power unit with 100ah battery ( think its the 2500 model ) , 160w solor, two fridges and load of LED lights. For the most part it works perfectly and for a few days its spot on, however the longer you are away, especially if there is a cloudy or rainy day it struggles to get back up to 100% before evening sets in and by morning your pushing the 20% mark. So normally on the 3rd day I have to really budget the lights we have on and turn off the console fridge between the seats ( its a compressor one, alpicool ). It's probably about right i guess that the more days it goes, the more likely you need to either drive to charge it, or put it on hook up for a while to get back to full power.
Obviously with Clayton having an expansion battery now, its expensive but also fairly big and with already limited space its not an option.
Soooooo, I've got a second van we now plan on taking on most camping trips at at the same time, If I was to put a 300ah lithium battery in it, with inverter. With this van it has minimal stuff to power, maybe the odd water pump or airfryer but for the most part the camper is doing the hard work. Would it be ok to then plug the 240v hook up lead into a socket in the second van, powered by the 300ah lithium to then give the clayton a quick hour or so top up every now and then ?
In my head i can't see why it wouldnt work, but at the same time im not an auto sparky so could be leading myself up the wrong path lol.
Running a power hungry device like an airfryer is going to need some serious infrastructure.
