Cbe Pc210 Control Panel
tcummins857
Hi I have a CBE leisure system in my T6. Today i was installing a new 12 v socket and when going to connect the negative wire to the lug at the bottom of the DS300 distribution box and existing negative coupling of 3 cables slipped and touched the positive wire next to it. Now my PC210 panel will not power up. I have checked all fuses and they are all fine and my non control panel lighting is working off the distribution box. I just cannot get the PC210 control panel to power on. I have cjecked the inline fuses coming off the leisure battery and it is fine. Any help would be greatly appreciated
Hi tcummins,
I have a similar problem with my cbe pc210, icannot power up the pannel. How did you solved it?
Thank you!
Any joy on this problem. I now have a pc210 control panel that no longer switches on.
All fuses are OK and got 12v running through to the fridge and other bits but the head unit can no longer switch on and therefore can't control the water pump and lighting.
