Carrista fault codes - central locking?
Mugwump
Carrista arrived and used
in order:
1st 17 faults cleared what could
2nd 12 faults couldn't clear them
Went for drive then re run carrista
3rd 7 faults headway!
4th 6!
so this one is central locking 03396
Supply voltage terminal 30?
can someone point me as to where it is please.
if I can get my central locking working again the others I'll sort later or find an auto electrician!
So £25 was well spent so far!
Going into hospital for an op next week and climbing around vehicle is a pain literally lol.
Post a screenshot of the 6 outstanding codes.
Here's the first 3 ! Which is the reoccurring as said down to 6 now so ignore the 12! other is Airbag, ABS, Air intake ( sorted) top of my head wrongly deleted other screen shot sorry! Could run it again if needed.
Found this on a T5 forum general search for issue
"Terminal 30 voltage supply relay is J317 (109) in the engine bay under the battery...."
Worth a look when I can !
Electrics sorted finally!
Myriad of small things, 1 fuse I reinserted one space down T30 terminal blown as suspected.
But told the new battery ( from europarts as recommended on thier list!) Was the wrong one mainly around stop start setup apparently! Not impressed as I assumed ( I know) that putting vehicle reg in etc and given a list of suitable batteries what I chose should've done the job! Mid priced one!
I always switch off stop start anyhoo but it wouldn't of lasted ! I also got told it would just need to be fitted ( as per normal ) as well, but it should've been "programmed in" by all accounts!
Still all sorted which is a relief !
After several calls I found a Southampton based independent garage that specialises in German vehicles mostly!
Foxtec
Very helpful
Note to self blurry modern vehicles and thier blurry electronic wizardry ha ha!
Oh and they actually put back fusebox cover and cleared up after themselves, unlike VW who wouldn't because I'd removed the cover.
Think it's called customer service/ going the extra mile etc !
