Carista - How I Done It -
CAB
Leisuredrive Vivante
T6 Legend
Standard factory fitted - I think H4 never checked.
@Qnapper, you have standard H4s which use the same bulb for both beams.
As Scotty would say,
"she canna handle it for long Cap'n!!"
I'm no expert, but they are not designed to light both filaments for extended periods. They do, because that's what happens when you flash the high beams, but not designed for driving with both.
H7s and THQ/clones have separate bulbs for both, so it's ideal for them , I will be ordering my Carista soon as I swapped my H4s for H7s recently.
Qnapper
Wanderer
That's fair enough, I will change it back this morning. Thank you for the advice.
mmi
Senior Expert
VCDS User
Moderator
T6 Legend
and below is the pricing structure:
A change...
dj_
Has anyone been able to disable the loud beeping telling me that the ignition is on (even when it’s on PARK).
Sometimes I pull up and just want to keep the engine running and grab something from the back and I get this loud beep when I open the door - it’s crazy.
Unless I’m missing something?
mmi
Senior Expert
VCDS User
Moderator
T6 Legend
On T6 you would press OK on the steering wheel. Or do you mean to disable permanently?
dj_
Oh I should try that! If it’s something easy like that I’ll be happy. Will report back - thank you
Reactions: mmi
JOG
Limp Member
T6 Legend
If you’re not quick, you could end up missing a T6!
  • Haha
Reactions: dj_
