1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Cali tail gate struts
Discussion in 'Interiors, Seating, Lining' started by B19DRG, 13 Feb 2018.
  1. B19DRG
    B19DRG Senior Member T6 Pro
    hi does anyone have a part number for the uprated tail gate struts from a California as had my tailgate lined Etc and it’s a bit heavy ! Cheers , Dan
  2. spook
    spook Senior Member VIP Member T6 Pro
    VW Transporter T6 Caravelle Uprated Bike Rack Gas Strut with a 2 year warranty and new fixings. Replaces part number(s) 7E0827550D
  3. spook
  4. superflyguy
    superflyguy Senior Member VIP Member T6 Guru
    Map
    Forum shop :thumbsup:
    I'm not a fan of the SGS struts I have fitted, not finished off as well as vw, and they creak loudly when opening the tailgate.
  5. Ads_Essex
    Ads_Essex Member VIP Member T6 Pro
    Map
    Does anyone know if the Cali (or any other) struts are the same length? I could do with my tailgate opening a bit higher... it’ll only be a matter of time before I crack my head on it!
  6. Pauly
    Pauly Senior Member VCDS User Admin Moderator
    Map
    They are all the same length
    Pair Of Genuine VW T6 Tailgate Gas Struts
    7E0827550B - Standard strut 900 N
    7E0827550C - Caravelle strut 985N
    7E0827550D - California strut 1200N
    Please note these part numbers are for standard vans/kombis/caravelles and do not fit californias
    B19DRG likes this.
  7. B19DRG
    Would the California strut be overkill for a tailgate ? Don’t wanna get the caravalelle and it not be ok ?
  8. Pauly
    Map
    The Cali 1200 unit is very strong and takes a large amount of force to close it without a bike rack on (have to use a bit of body weight to get it down)
    If you have put sound deadening etc in there and its a bit weak i would go with the 985 units but its all down to how much weight you have added (bike rack is circa 14kgs)
    B19DRG likes this.
  9. Loz
    Loz California 204 DSG 4Motion MY17 VCDS User Admin Moderator VIP Member
    Map
    Mines okay without bikes as long as you don’t leave it up in the sun then they are almost impossible to get down..
    BiTurbo and B19DRG like this.
  10. B19DRG
    Thanks guys I’m a little bit confused, guess I’ll go with the 985 , hope that works ok
    Fish likes this.
  11. andys
    andys Senior Member VIP Member T6 Legend
    I uprated mine to 985 and regret it a bit as it can still sag just slightly and I occasionaly crack my head on the corner. I don't have a bike rack, just lots of stuff like grip mats, ramps and little shovel plus sound deadening stuck to it so I'm thinking the 1200N Cali struts might be a bit overkill. I think I'm going to order them and fit one 1200 and one 985 as a compromise and see if it works.
    Nick-C likes this.
  12. StudleyGlass
    StudleyGlass 150 DSG Kombi Highline VCDS User Moderator VIP Member T6 Legend
    Map
    I have upgraded to 985s on my kombi tailgate because i have fitted a lot of sound deadening and fitted the vw interior covers. They do work ok but i agree with @andys you still need to careful and make sure it is fully up so you dont knock yourself out :(....maybe 1200N one side and a 985 the other would work ok but i would be worried about the imbalance when closing them as it my twist the tailgate with different forces on either side ?
  13. B19DRG
    Got the 985’s fitted , work out just fine
  14. andys
    Yes that was my worry. I'm thinking I could close it with more pressure on the 1200N side but I don't know how it'll work, I'll report back
    StudleyGlass likes this.
  15. Ads_Essex
    Map
    I think I should have realised - my tailgate conversion relies on aftermarket parts made for a T5, and apparently the struts are longer on a T5 compared to the T6, so that’ll be why my tailgate isn’t, erm, fully erect.
Share This Page
