Cable routing layout for under passenger seat.
flo.flowers
I’ve had an unsuccessful search for pictures & posts of cables coming into the cab from the engine compartment to be routed under the passenger seat.
It’s the routing I’m actually after recommendations for.
Should I go down the centre as per the factory loom or follow down the wheel arch and run along down by the step?
3 cables; the dc-dc +ve, the 1.5mm2 arctic and a 6mm2 cable.
Cheers,
flo
Cheers,
flo
Hi mine sort of went like this ...but I’ve got carpet on top so not too tidy :)
ps....from the rear of the battery you should find a grommet this gets the cables into the scuttle area ..remove trim under wipers.. on the passenger side more grommets this gets the cable into the rear of dashboard
Personally I'd run them down the centre. You've got space to hide them without them being felt under foot.
I ran the power cables from the battery grommet down the L/H wheel arch and around the step as there is a void there under the top flange of the plastic trim so nothing gets squashed or felt under foot. They can be routed in from the base of the B pillar as there is already a large channel there under the mat with a conduit. I added all the wiring from the cabin here too as these all came down the B pillar from the roof. Everything from the dash runs down the centre following other cables from the factory as in the picture above.
