C-TEK 250SE
Hi everyone,
Just a simple question. Is the C-TEK250 SE suitable/capable of charging 2 x 100ah AGM batteries set up in parallel?
Thanks in advance
yes, it will just charge each at half rate, so about 10A ish each battery.
remember to fuse every POS battery connection.
They are separate power cables and susceptible to separate faults / over current.
As above.
The fuse is there to protect the cable.
So every cable connected to either battery needs to be fused.
