Brake light error - help! Anyone near Bedfordshire with VCDS?
NoGearNoIdea
Hi everyone!
Apologies if this is or isn't the right place for this post. I've found and learned so much from this forum but am having a real headache with my current problem.
I have the bulb out error come up on my dash when I depress the brake pedal. I have changed the bulbs (despite the bulbs working), tried checking and clearing codes with carista. Sometimes, on a really got day the error doesn't come up?
Anyway, long story short as all the bulbs are working I was wondering if anyone in or around the bedford area might have a vcds with which they could help me out, either by tracking down the problem or forcing the system not to check the rear lights etc.
I am happy and willing to pay anyone that can help me and am willing to travel a reasonable distance. Its one of those infuriating things that gets to me, I live this van and every time I get in it and see that bulb out late it really winds me up!
gerry
VCDS User
Byte 19 Bit 7 Lamp Diagnostics for Brake Lights active
uncheck bit 7
Dellmassive
204 T32 DSG LWB SPORTLINE PV MY18
VCDS User
Moderator
T6 Legend
Possibly try a reset..?
NoGearNoIdea
Meanwhile
What faults are reported by Carista?
Sorry but also the third/high brake light? Before depressing brake - probably have tried turning on/off all the other lights, fogs front/rear, indicators, hazard, etc? DSG or manual?
Ah, I've not changed the high level lights, again they illuminate. I've turned on and tried all lights its only when I press the pedal that it comes up. Hadn't actually thought of trying to swap them out, just assumed being LED they wouldn't blow or cause an error.
Its a manual. 2012 T5.1 T32.
The only fault that comes up on carista is a stuck actuator flap for the air con (also not working, but that's another days headache)
Reactions: mmi
mmi
VCDS User
Moderator
T6 Legend
Now that's even more interesting if the related fault is not shown. Did you scan while having dash warning on? There definitely should be a related/clarifying fault code - however, turning ignition off/on turns the fault "inactive" thus possibly Carista is failing to show it - may be... haven't played much with Carista.
