Evening All,
Today, I finally got round to installing the PF Jones Tow Bar kit for my T6 (without Trailor prep).
All went well until I got to the coding part, and I'm now left with a van where I have loads of issues likely due to me messing up somewhere.
Issues:
Central Locking, Lights, Electric windows are not working. (one window does intermittently, the others stuck down. Tailgates locked shut and not able to open. Sliding door shows as open when its shut).
Things tried:
Scanning and deleted error codes
Deleting the Trailor gateway in vcds.
Disconnecting the negative/ touching the negative/ positive to drain BCM.
I've removed all wiring from the PF Jones kit to try and take me back to where I started this morning when everything was working.
Van does start and drive, but I have the EM Light on and light out warning.
I've checked all fuse boxes in the cab/ engine bay, and all are okay, nothing is blown.
I've read several similar threads but and tried those steps mentioned to no avail.
I did do a scan of the van before, but it wasn't a full scan, so I messed up here and I'm not sure what to do next.
I've attached the latest scan(s), and I'd be really grateful if someone can help me out, or give me some pointers.
TIA
Issues:
Things tried:
TIA
