Bcm Pins
Littleblackflash
Auto Engineer
VCDS User
i need to add a wire into my BCM for my tailgate conversion. What’s the pin part number or where can I get some?
There are three or four different connection types (pins or prongs) and then the larger ones have options for different cable sizes depending on what you are trying to connect
I have a variety of them here if you know what type you are after
Hello, I have serious problem with installing LED headlights. I should know what is part number of BCM B connectors crimp terminals pin 3 - 10. It seem to be different than normal ones. I'll try to wire T73b/5 and T73B76 to headlights.
Thanks in advance.
Dragging up this thread again.
Pauly supplied me with most of the pins I needed to wire my tailgate and other options into the BCM. I'm missing one pin for connecting the rear heated screen to the BCM. Pin - T73b/63. It's a 2.5mm mire and the connector look about 6mm wide, not the normal small pins.
Does anyone know where I can get one given the shop has now closed?
Thanks Deaky.
I've used this supplier before and he's really helpful, but I don't know the part number of the pin I need. I've sent him a message and I hope he can help again.
Duncan
Thanks Robert, I have those pins but position 63 is much larger. It must be 6.3mm wide and its for a 2.5mm2 wire. Where did you find those part numbers? Is there a look up diagram somewhere.
It is from my experience working on BCM;)
Reactions: mmi
