Battery drain central locking fuse
landyman
Locked van up with alarm disconnected ( button on pillar).amp reading 2.6 amps.finally shuts down to .56 amps removed 2nd fuse down 5 amp and reading goes down to .01amp..central locking fuse..
Still under warranty but would like to be 1 ahead off them. Any ideas whats causing it znd what to check next.the vans been converted but all is independent of main battery. Charges with solar..no split charger ect.cheers chris
Got any pics of the battery conections?
And a list of extra kit you have fitted?
Any BM2 or other battery voltage logging?
Vw spec for draw when sleeping is 50mA
Edit... B puller button just disables the ultra sonics or tow away tilt sensor.
Had new battery fitted inder warranty.
Connections fine.only added bits are tow bar electrics.have disconnected them .no difference at all.its all down to the 5 amp fuse.have left out and going try tomorrow as its been parked up since
[/QUOTE]
[QUOTE="Dellmassive, post: 326053, member: 4226"
Pressed pillar button as the sensor would pick me up and sound alarm
They should be in the same places but less of them.
which fuse number from my pic is it?
