Hi all , just purchased ctek battery charger MXS 7 which is suitable for AGM batteries and leisure battery.
I've bought the battery fly leads so I can permanently attached them to the battery and the charge from inside the van via a 240 volt connection .
When trying to connect the negative to the battery the 10mm nut will not fully undo , preventing the fly leads hooped connection to be fitted.
Should I replace the end hoop connector with a two sided prong type or connect the negative to the vans chassis?
It seams that VW don't want any additional connection to be made to the ground of the battery.
Any thoughts on maintaining the condition of the batteries due to the van being stood for long periods of time would be appreciated.
