Barn Door Handle Cord
Dazmitch
Hi I've just fitted a rear camera to one of the barn doors and can't get the pulley for the top catch to work any more. There is an L shaped pin on the cord that is supposed to go in the hole and held in position by a plastic clip but the clip no longer holds it correctly and it pops out as soon as you pull the handle Can anyone send a pic of what it's supposed to look like and any advice on how I can fix it
Click Google Drive to see picture I took
Doh.
Put the end of the metal rod in the hole. The white clip spins round 180deg to the photo's locking it in place.
Ahh so your saying the clip holds the wire section not the L shaped metal piece? I'll give it a try later. I just couldn't seem to get the L shape piece to stay in that hole when i was trying the other day.
not quite.
The white clip will rotate. Insert the metal rod in the pivot of the write clip and then rotate the clip until it grips the L shape bit.
