b6 bilstein t6 comfort
SofaKing
Anyone fitted these?
I’d like to keep the height, but reduce the body roll on the car. Keeping the stock springs, or should I?
Many thanks for your tips!
No experience with the B6s but my own view is that it's best to go with either a set of dampers designed to work with the std springs (which is how Bilstein describe the B6) or go with a damper and spring designed to work together.
With the B6s alone you will doubtless gain better body control with a firmer ride.
Bear in mind that you may not see the reduction in body roll that you expect (with the dampers alone). Dampers are more about dynamic control whereas springs support the vehicle weight and are more influential on 'static'/less dynamic (!!) situations.
My own view - see if you can find a friendly T6 owner with the H&R roll bars and have a trip in that.
If you are principally after a reduction in roll I would go down the H&R route - this path will also have the benefit of altering the handling balance away from understeer.
The springs support the weight of the vehicle, and the dampers control the springs movement and reaction to the forces put on them.
So, I made some enquiries about the impacts of a change of damper, and I was told the following:
Those dampers (I asked about B8 which are a shorter version of B6) offer 30% more damping than standard, so they will reduce body roll. The will not necessarily improve comfort on bumpy roads as the springs will react slower. Being gas dampers they will not be prone to fade.
You will struggle to do it yourself, wheels need to be off the ground to release tension from the bar as its always sprung so needs a ramp really
It would be possible to do it but very tricky especially on the fronts where access is much more restricted
Thanks. I have acess to a lift, but will actually try hear with local VW workshop of they will do it...
I agree. It's not so much a question of simple access but being able to fit the new bar which will involve applying enough controlled force to overcome the pre-load.
