Auxiliary Heater - self-bleeding?
Unimog
I am about to drop the fuel tank to install a pick up pipe for an auxiliary heater.
When it comes to reinstalling the tank and I have re connected the fuel lines, do I need to bleed the system or will it self bleed.
I have a 2017 150hp
thanks
You've probably already got it started by now but turning the ignition on but not starting the engine a few times will reprime the system from the lift pump to the high pressure pump.
I just started mine as normal. Started and Ran exactly the same as always.
