Sold Autoterm Q-start modem £80
nuggetwillow
For: all AUTOTERM heaters
Assy: AT0060
Technical parameters:
Modem QSTART is a Plug & Play device with the ability to use Autoterm Control application on smartphone (available at Google Play and AppStore) to control any AUTOTERM air heater and liquid heaters.
Application "Autoterm Control" together with modem QSTART will let you to operate and oversee your Autoterm heater via GSM / LTE network.
Main advantages of "Autoterm Control" application:
Remote Start/Stop of heater
Start heater with pre-set working duration
Current status check
Temperature check
Operation settings
* Modem QSTART uses micro sim card slot
Antenna wiring length - 90cm
Modem 3-way cable length - 5x5x5cm
To increase wiring length from modem QSTART till control panel a 2.6 meter extension wiring for control panels (assy.4269) can be used.
The wiring length from the control panel to the modem must not exceed 10 meters.
** Please note, For Modem QSTART to be connected to AUTOTERM Air series heater a 1.8 meter control panel wire (assy.2067) must be used.
The wiring length from the heater to modem must not exceed 2 meters.
*** Please note, Modem QSTART will not work if heater is equipped with control panel PU-22.
For modem QSTART to work, control panel of the heater must be changed to Simple Control, OLED Control, or Comfort Control.
Download APP for iOS here
Download APP for Android here
If you have trouble to install app on your new android phone, please use direct download link. We are sorry for inconvenience, new app is still in progress
Direct download for Android here
More information
Manuals & Certificates
Package contains:
1 x Modem QSTART (LTE version)
1 x Antenna
1 x Harness for Modem Qstart (assy.3282)
1 x Quick start guide (manual)
Supported GSM bands:
GSM/GPRS: 900/1800 Мhz
Supported LTE bands:
LTE Band
Up-link Band (MHz)
Down-link Band (MHz)
Band Width (MHz)
Duplex Spacing (MHz)
Band Gap (MHz)
LTE Band 1
1920-1980
2110-2170
60
190
130
LTE Band 3
1710-1785
1805-1880
75
95
20
LTE Band 5
824-849
869-894
25
45
20
LTE Band 7
2500-2570
2620-2690
70
120
50
LTE Band 8
880-915
925-960
35
45
10
LTE Band 20
832-862
791-821
30
-41
71
LTE Band 28
703-748
758-803
45
55
10
Modem Qstart is suitable following AUTOTERM air heaters:
AUTOTERM Air 2D if connected to Simlpe Control / OLED Control / Comfort Control control panel
AUTOTERM Air 4D if connected to Simlpe Control / OLED Control/ Comfort Control control panel
AUTOTERM Air 8D if connected to Simlpe Control / OLED Control/ Comfort Control control panel
AUTOTERM Air 9D if connected to Simlpe Control / OLED Control / Comfort Control control panel
Modem Qstart is suitable following AUTOTERM liquid heaters:
AUTOTERM Flow 5 (Diesel/Petrol) with serial numbers that start with "E...." if connected to OLED Control or Comfort Control control panel.
AUTOTERM Flow 14D if connected to OLED Control or Comfort Control control panel.
To connect QSTART modem to liquid heater AUTOTERM Flow 14D, necessary additionally order Modem harness-adapter assy.3814
LLC "AUTOTERM"
RN: 40103579550
72 Paleju street, Marupe,
Marupes district, LV-2167,
Latvia
Sales department
+371 2011 0229
sales@au
toterm.com
autoterm-europe
OEM Sales
+371 2939 5114
[email protected]
Technical support
+371 2552 9999
[email protected]
autoterm europe service
© LLC AUTOTERM
Seems the app isn't officially compatible with my phone being on Android 15. Hmm, would you take £70 as a bit of a gamble in case it doesn't work for me?
It is £129 to buy of auto term .it works on all android phones and apple phones .£80 is the best I'll do
Go on then I'll take it. The app isn't available on the Play store for my phone being on Android 15, I literally cannot download it from there, so can't be sure of its compatibility from any other source.
