Another Steering wheel change
Virtualmeuk
Hi Folks,
Would anyone be able to confirm if all of the following will fit? Before I go disabling the van by stripping the buttons and wheel etc off the van and thus disabling it, My question is, do the flappy paddles just plug into my existing buttons or will I have to find new buttons with paddle connections? Any advise or comments welcomed.
The van is a 2016 Euro5 DSG Highline Base Van and I want flappy paddles and a flat bottom wheel. My current setup is a round wheel without flappy paddles.
I Then managed to get this one for a steal and my plan is to remove the black fascia, replace the buttons with the buttons from my wheel and then all should work because electronically, the buttons are as before. My question is, do the flappy paddles just plug into my existing buttons or will I have to find new buttons with paddle connections?
Hi - have done the same swap, the paddle shifters have a small loom with a white plug that will plug into your black surround and buttons - - remove the whole of the black trim c/w buttons off old wheel and fit directly onto the flat bottom wheel - suggest having a warm wheel/trim and take it easy with trim tools - be careful when pulling the black trims of each wheel - wiring is tight - especially for the paddle shifters.
Done the same swap too, found a flat bottom steering wheel on marketplace in mint condition for £40. As Nick said about just take your time and use trim tools.
