longtallmartin
I have a 2017 T6 102hp 28cwt with approx 10,000 miles. Converted to camper with solar panel fit courtesy of Vamoose. I had to have a new battery at start of 2019 due to dead battery. After recharge by AA and diagnostic checks they scrapped original battery and replaced with new Varta battery. My van had a history of poor performance and endurance from the leisure battery.
Since the change I checked voltage of battery & became very aware of the battery voltage being low when engine idling. I have established that unless (A) I switch my heater blower to position 2 or above or (B) switch lights to main then my Alternator does not kick out a charge and my battery voltage at stationary will read 12.5v or lower depending upon vehicle charge. No indication of a no charge condition is indicated. Switch on A or B and I get 13.3v at the battery. I queried it with VW at service in march 2019 & they who say the van is perfectly serviceable. I am now trying to take VW to task as I believe this is another VW emissions fiasco. The no-charge alternator will give good emissions with nothing switched on. No cheating with emissions software but i have no charge to my van battery or leisure battery system when I drive the van on daytime conditions without blower on 2 or above.
Does anybody else have the same issues. I believe this wouldnt have helped the original battery and would likely have contributed to its failure. Local dealer suggested driving around with aircon switched on. Aircon switched on doesn't help unless at blower posn2.
I queried the vehicle again with AA who carried out battery change and technician confirmed my diagnosis as correct. Take back to VW he said as appears to have poor voltage sensing condition??
I now drive with A or B switched on and I then have excellent leisure battery condition. This may help you guys with start issues due to flat batteries. No indication when van charging system isn't charging ie a Mil light switched like in old dynamo days.
