Adding A 12v Socket!
Youdy
Hello all, need some help! I want to add an extra 12v socket in my van to my Sargeant EC160 PSU, but I’m not sure which terminals to wire too. Im currently running a twin USB socket & heater from the unit with the normal lights, water pump & fridge.
Mark
Welcome to T6F @Youdy
System User Manuals | Technical Support | Sargent Electrical
fused outputs and grounds listed in PDF, or use a good chassis for ground.
be cautious with "the heater" . . . . what one is it? how much power/current does it draw?
That EC160 can only run small devices as per above:
5A pump,
10A lights/aux
10A Aux
5A perm
15A fridge
all the above fed from 2x15A (30A) feeds
Installing 12v Socket /s - How Its Done -
Come join the VIP club - VIP Membership | VW T6 Forum - The Dedicated VW Transporter T6 Forum
Hi @Dellmassive and thanks!
Our van is a professional conversion but I forgot to spec the extra 12v socket, which I wanted to position nearer to my 12v TV when I’m off grid. I thought I could use one of the 12v sockets in the cab for short periods, but I don’t want to risk flattening my van battery?
Currently my fridge is wired to the perm 12v out terminal (as it has an on/off switch on the front) and the fridge out terminal is free. Can I use this for the extra 12v socket and change the fuse to a 10A??
