A
Account Closed
Guest
I had 4500 left in the tank (13ltrs) and when I topped it up it took about 8ltrs. Now i top it up every Saturday as part of my weekly checks
Wow, what mileage are you doing? I top mine up roughly every 3000m and there’s always loads left at that point.I had 4500 left in the tank (13ltrs) and when I topped it up it took about 8ltrs. Now i top it up every Saturday as part of my weekly checks
It’s probably best to wait till the mfd pings up saying it needs filling about 1500 miles left, then only fill it what the min/max amount of gallons says as over filling can drown the ablue sensor causing adblue faults to occur.I had 4500 left in the tank (13ltrs) and when I topped it up it took about 8ltrs. Now i top it up every Saturday as part of my weekly checks
Had a call from the dealer today apparently they have traced the problem to a tiny leak in one of the adblue pipes although also still waiting for info from VW. He says this is the first time they have come across this and he described it as a bit of an epic to find it! I am looking forward to the full report on Monday!Last Monday driving back home from Cornwall adblue warning came on, it went from 5000 miles to 650 but intrestingly the max min fill info did not show up also subsequently on start up a message came up saying DEF error . I took it into the dealership today(7.30am) to check up, spoke to them late afternoon and they have a technical query in with VW so will be very interested as to what the outcome is! This is the 3rd or 4th time an adblue issue has come up so with a few long trips coming up this year I hope they fix it! Van is a 102
Picked up the van today and the explanation for the adblue issue was that the tiny leak found in the pipe was causing a pressure problem in the tank , so when the adblue pump pulsed to inject it the level in the tanks was not compensating so the gauge read a low reading and then could not reset hence the drop from 5000miles to 650 but no max min level showing. They had some very long conversations with VW tech but now say problem fixed ! we shall see, as mentioned earlier we have a number of long trips coming up over the next 6 months or so. As a precuation of have noted positions of VW dealers in Scotland!! Really hope this is a fix I only have 12 months warranty left!Had a call from the dealer today apparently they have traced the problem to a tiny leak in one of the adblue pipes although also still waiting for info from VW. He says this is the first time they have come across this and he described it as a bit of an epic to find it! I am looking forward to the full report on Monday!
I think adblue consumption is down largely to driving styles ie heaviness of the right foot! There does not seem to be much of a correlation between miles covered and adblue used!I still think the Adblue range indication in MFD is bother! I have just got back from a round trip down to Malaga, at the start of trip the Ablue range said 5000 miles, we did just over 2400 miles and it now says 4500 miles still available WTF?
Probably only me that didn’t spot it, but there’s a spot for the AdBlue cap when filling!
Need to make sure it’s clean before putting it back on though.
