Hello fellow T6 owners!!!
Am I correct in thinking that this is just a faulty seal on the A/C compressor solenoid? Has anyone else had this issue before, if so was it an easy fix?
I believe it's a Garage job as the system will need draining and refilling
I'm just after reassurance
The only way is to degas, pressure test with nitrogen. Most leak are where the pipes join. You can buy the seals about a quid each. Once it holds vac out and then weight the charge into the system.
