Although a quick look on ebay.de searching for T6 4motion cardan found
this. Cheap enough to just buy.
Okay thanks just seen link
So Is that a LWB picture that shows the prop centre bearing support .....? Im guessing so ...
Also I have full running gear from a 17plate T6, Gen5.... I am guessing the ETKA drawing is earlier generation as my driveshafts mount on splines (piddly sketch but drawings usually follow the part form(not suffixed changes... h,j,k ... but unit drawing) where as this sketch shows 6bolt flange connection ... I don't have heat shields on mine according to etka also)
So let me get this right please, is this what you have swapped out ... ?
1x front inner handbrake cable
2x rear cables
2x midway brackets
1x abutment bracket + couple of rivnuts inserted
and a few clips to hold cables on rear arms ....
The old cable brackets are going between the inner rear arm mounts.....
Hopefully those x2 big holes line up for rear subframe mounts, captive nuts or welded nuts in brace across from both wheels.
Then the 3rd .. front mount... do you know if this is flush to the floorpan... or does it have some box section on 4mo's to sit it off the floorpan level ..?
(this is why I been bugging cordwallis commercials for a peek underneath one)
many thanks in advance bud .... rolla
