3 simple questions...
snoop6060
Well I am simple! Bare with me :)
1) do you need a fuse between your lesuire battery and your fuse box? I didn't get one in my kit from @travelvolts so I'm fairly certain the answer is no!
2) can you wire a 12v fridge via the fuse box rather than direct to the lesuire battery. My +ve terminal is full. Took me ages to get the 4 things it has on the on in a tidy way. I really don't wanna change it. I have 12 way fuse box so plenty of room there. Almost everything says wire it direct though.
3) Where does the temp probe for the ctek dual 250 supposed to go? It's about 2 foot long suggesting not close to the unit itself, though not quite sure what use it is anywhere else.
Si
1) not if the cable run is short and there is no risk of damage or chafing. You can always add a post fuse at a later date if you end up relocating either one and need a longer(and larger cable).
2) yes, as long as you can fuse it to 10A
3)sticks to the side of the battery to measure its temperature.
Thanks, Loz. Very helpful. My fuse box cables are very short (less than 30cm for sure) and well protected. And tied down tight so nothing should be able to damage them.
I shall stick the thermometer to the battery shortly
