240v to 12v DC Power Supplies.
T6VanLife
Can anyone recommend a quality 240v to 12v DC power supply about 150-250w ? all I can find are these cheap ones on Amazon & eBay which I am not sure I trust !
As I want to power my diesel heater and some 12v lights with my Bluetti EB55, but the 12v output is limited to 120w which just ain't enough to power the diesel heater on startup which needs about 160w and run the 60w lights at the same time.
12v @ 30A,
with DC Powersupply mode bult in.
you said quality . . . but quality dont come cheap.
FYI i have two of these and can vouch for them.
Thanks Dell, not really phased by the price i have already shovelled plenty into this van ! So long as it works and is safe & reliable that's all that matters.
My electrical knowledge is limited not come across those before, it says their a battery charger, but is it a case of put a standard 3pin plug on the input and hardwire your 12v appliances to the output ?
It comes with a UK plug already.
Just plug in and change the setting via the app to power supply mode.
Screenshot_20241215_092252.jpgScreenshot_20241215_092249.jpgScreenshot_20241215_092244.jpgScreenshot_20241215_092241.jpg
That's great thanks for that @Dellmassive, I think that's probably the way to go for my requirements, I have just been reading the online PDF of it and I was wondering if the Unit saves its settings after its been unplugged ? as its not clear in the manual.
For example if I switch the unit to "Power Supply Mode" as above, then after a few hours/days/weeks of use I unplug it from the PowerStation, will it default to "Charge Mode" the next time I plug the unit back in to a power source ?
They retain their settings.
Thanks Salty :thumbsup: right I am off shopping my wallet's away to absorb another shoeing................... :cry::whistle:
Yes as above, settings are saved.
There’s also the ip67 version if you fancy one that is waterproof and fanless. Slightly more expensive though.
