204 Glow Plug Removal?
Fluff34567
Swiss member
Anyone here have a guide or experience on changing glowplugs on a 204?
As mine is fairly new and the nightmares of changing plugs in later years an application of nickel anti seize may be a good idea.
Do it with a hot engine,
Use a tourque wrench to undo and tighten,
Use the correct tool.
Remember one of the plugs is a special one with in cylinder pressure sensor.
I'll dig out the procedure if you need it.
Hi, if you have a procrdure/ workshop manual page that would be greatly appreciated. PM is also good. Thanks !
