A much smoother ride Oli, just not sure about even tyre wear?Yes give it a try and see how you get on.
Also, I think 275's on the front are too big. That was the recommendation and what I opted for, I'm looking at a smaller size now.
I’m a T32 on 20” rimsOn what size rims and for what weight rated vehicle?
Thanks, much appreciatedBetween 36-40psi.
On kombis and panels, we've found the sweet spot to be 36psi. Very good even tyre wear.
HTH
Many thanksWheel bolt torque is 180NM
Or in old money, 139.39924622 foot-pound , 10 stone per foot of leverage.Wheel bolt torque is 180NM
or a good lean on a 3-foot breaker bar.Or in old money, 139.39924622 foot-pound , 10 stone per foot of leverage.
This oneor a good lean on a 3-foot breaker bar.
I’m running 275/40/20’s.... 42 psi up front and 40 at the rear. Mine’s a converted panel van, fully sound deadened, insulated and carpet lined, but a day van, not a full on camperHi all, recently joined the forum as just literally collected my first ever VW Camper, and am delighted with it.
it has 20 inch wheels/tyres on with 275/40/ZR20 106WXL tyres. The converters said run at 50 psi all round, but checking them today, each wheel has a different pressure in, ranging from 32 up to 45psi, so shows how much they checked it before PDI!!
so, people running 20inch rims, what pressures do you use/ recommend?
also, what Torque figure is the correct figure to use, when tightening the wheel nuts.
any help and advice is much appreciated
I haven’t heard of HAIDA either, so couldn’t/wouldn’t comment, but my opinion is if you’ve paid good money for a good van, don’t skimp on good quality tyres.... from a safety point of view mostly! Those tyres are your only contact patch with the ground. Buy the very best you can afford. Obviously you’ve got what came with the conversation, but I know that forum members @BognorMotors and @ChrisR recommend Goodyear Eagle F1 AsymmetricThe tyres that came with the conversion are HAIDA.
any comments? I take it they are budget tyres, as haven’t heard of them.
what generally is a good tyre for. 6.1?
Thank you.Goodyear F1 would always be my recommend. Nice and quiet. Work well in wet and dry and last well.
