Sold 18" JBW Steel wheels in silver, OEM plastic centre caps and OEM wheel bolts
Duncan Mowlem
for sale 4 x 18 JBW steel wheels,
c/w with vw centre caps and bolts
Currently fitted with 255 x 45 x 18 frostrak tyres - close to legal limit - will need replacing
powder coated in spring 2025 in silver
£320 ono please - collection from Telford, shropshire. 1761840186235.png1761840635938.png
Do you still have these?
What offset are they?
What's the wheel width?
Need to know if they will fit over my front brakes
hi, yes, wheels are still available, a forum member is possibly having the spacers - TBC.
wheels are,
Technical Specs
Width
8"
Diameter
18"
Fitment
5x120mm
Offset
45mm
Poke
69.3mm
Backspace
159.3mm
Center Bore
65.1mm
Weight
18.50kg
Weight Load
955kg
hope this helps.
wheels, centre caps and wheel bolts still available - £320 ono, collection only. (Telford, Shropshire)
thanks.
Duncan do them jbw wheels take vw standard bolts? And how do you go about balancing the fronts? Just like normal alloys or them old style steel waights?
yes, these wheels work standard steel wheel bolts and they are included with the wheels,
wheels are balanced with stick on weights out of sight, not the old knock weights like back in the day.
hope this helps.
I'm considering these and getting a set of winter tyres on them but concerned of they will look odd on my van 🤔
Currently on 20's
Currently on 20's
i personally think these steel wheels look great..... i have more people complimenting about the steels than i ever do with my 20"s fitted... your running quite low so i think they would look good....
