02256 static current battery fault vcds.
Dm85
Hi all,
I am getting a static current fault code pop up every morning I check so means there is a draw. I have a dash cam but pulled the fuse and fault code still came up.
I was checking the engine bay with a volt tester, one lead on battery and the other touching other grounded parts of the chassis which all read 0v but when I touched the metal case of the charge cooler it read 0.28v
Could there be an injector wire beneath it touching? Tested other parts but only this one shows up a voltage.
