I'm just about to install the cabling for the split charge relay from the main battery to the the underside of my drivers seat. I have ordered a proper battery tray for my leisure battery. (the battery is one that will fit height wise ok under the seat). But, the slight confusion I am having is...
I bought my van already converted over a year ago. After reading tons of threads on the forum I'm not sure the electrics are setup the right way. Mine is setup with a voltage split charge relay (see pic attached), and a flooded acid type battery.
Is this the right setup for the way the Euro...
This guide takes you step by step through fitting @travelvolts DC-DC charging kit for leisure batteries.
Why fit this kit:
VW are still installing their standard split charge relay on vehicles fitted with leisure batteries, however, the latest Bluemotion technology has a few undesirable side...
Hi Guys
Ok i have a t5.1 12 plate and have always just ran 25mm2 to the front seat from a Duralit 140amp split charge to 1 or 2 banner batteries and all has been well in the world
Now i've took the plunge and ordered a euro 6 Cherry red LWB van with lots of options for march 1 delivery
So...
