When lowering my van the other week me and @Kyle lannerz discovered this cable in the o/s upper strut cavity. I have tried to plug it back in but it is 2 male connections there
When plugging the van into Carista it is showing a rain/light sensor fault is it something to do with that?
I am 99% complete on my heated screen retrofit, it all functions fine just not quite the way I want.
it will work via the separate button setup as most of them are But I want to control it via the climatronic panel over CAN
(You can just make it out on this pic)
as mine is a T5.1 I have a...
Had my heated front windscreen replaced a few weeks ago and now only the passengers side heating works. Fuse keeps blowing on the drivers side. Have seen the wiring diagram and looked at the connections but newish to the transporter world so not sure if it is connected properly.
Can...
Never had a heated windscreen before, but pretty sure it's not designed to work like this.
Can someone confirm that it shouldn't leave a strip of ice.
The van is only 2 months old so should be covered by the warranty.
Hi all, I’ve searched and downloaded the fuse layout but to be honest quite confused as to which fuse it could be for my heated screen. Can anybody help as it’s not working at the moment
or does it just take sometime to warm up?? I ask as we used to have a ford and the screen was instant
thanks
Hello,
I have a Caravelle T6 from 2016.
I'm using it in Lapland during the winter. It's cold, and very cold... :D
I need to use the defrosting windshield (I have the option), but the timer is too short for me, I need to push the button too often.
Do you know if it's possible to change de...
Hi, so with the cold weather being here I have used my brand new T6's heated windscreen. However it doesn't work or at least half works. clicked the button and the near side works fine and feels hot, offside is cold to touch and didn't defog or defrost windscreen.
Any thoughts or trouble...
I havnt had the T6 long, so this is the first time I have had a chance to use the front heated screen option as it was a bit misted up this morning.
However, in a few seconds I could see a problem, see picture below (taken badly) where only half of it is working. typically the fault is on the...
Evening boys n girls ,
Just walked up o my van and noticed my screen is cracked .
Now I just wondering before I get it changed is there a way to retrofit the heated screen option, and if so what sort of price would I be looking at?
Cheers in advance.
Tonight for the first time, I tried to use my heated front screen. The windscreen was misted up but the heated front screen had no effect whatsoever! I've consulted the hand book.....and surprise, surprise, it was pretty vague. It just got me thinking.....does it clear mist or for some reason...
I should have never have got this van. Always liked hacking about with stuff but the most expensive thing I've generally messed with is a fridge! Then I got a T6, bad idea.
So I have installed a GSM relay into my lesuire electrics. I can trigger 4 different circuits from an app and have 2...
