Got an interesting fault, with the lights switch set to "auto" all works fine no errors. But if set the lights switch to '0' or lights on eg side lights I get the bulb fail light error on the dash. Had a careful check round all the lights, they are all okay. Its a t6 highline 17 plate with...
Hi guys,
Hopefully a simple answer.
A friend of mine retrofitted led headlights last year to his T6, headlights only, no self levelling. Since then his bulb warning light is on anytime his headlights are on, is it just a case of deactivating in VCDS (I’ve seen tick boxes for light diagnostics)...
I am sceptical about LED bulbs and have seen some really poor beam patterns and DAB problems but today I have been speaking with a local automotive lighting importer about the newer LED bulbs available.
He has asked me to take my van in and they will try a few different types so we can check...
Help needed, rear lights not working.
After installing the new seats and swivel my rear lights do not work.
I have a few cables left and not sure what they are.. Turn signals work. Stop and rear fog light work..
In the meantime I was installing a pop up roof so not quite sure when they stopped...
I've converted my barn doors to a tailgate with LED lights. But I have a orange warning for bulb out on the instruments.
VCDS scan showed no fault codes.
If I go into 17-Instruments and go into measured values, what should I be looking for? The only concern I've found is "Status on input...
Is there anyone in the Leicestershire area that can help with an issue?
I've got a MK7 Golf as well as my T6, and just swapped the Golf steering wheel with the T6 one, giving me a flat bottom wheel with the all important paddles.
The T6 is all sorted and working perfectly, but my Golf is now...
Fitted replacement LED fog lamps the same as some of the guys have recommended on this forum .Thought I'd leave the covers off the inside wheel arch until I'd tested them . I wanted to cable tie the two driver units to the wiring loom to stop them sliding about which could eventually loosen...
