Hi guys, I wonder can anyone help me with this issue?
I have a brand new T6.1 4Motion with LED headlights. I've fitted a 17" wheels with 245/65 BFG K02s and a 35mm Eibach lift kit. With both these mods the height of the van has gone up significantly.
The issue I now have is that the headlight...
I have a problem with my LED headlights pointing straight down after I lowerd the van on some B14s. Did not have that problem with any of my BMWs with xenon lights. I have checked that the sensors are OK, but I think that they might need some shorter struts because the van is so low and might be...
Can anyone explain why my headlamp beams are now higher after suspension mods ?
The rake is obviously different, but I thought the DRA compensated for it.
I don’t have an adjuster wheel inside the cockpit, so if I had a heavy load I would blind people.
Hi I couldn’t really find any links from reading a few other threads but does anybody know of any decent aftermarket auto headlight switches than can be swapped for my Standard headlight switch on 2014 t6. I’ve fitted one before on my caddy that came with the sensor, really easy to do, I just...
Has anyone retrofitted DRL to a T6 and had problems with the dashboard illumination? Mine keeps going from dull to bright when lights are either off or on sidelights, once on main lights they stop??
I have a T6 with H4 headlights and when Auto is selected the dipped and side light are lit, not DRL. If I switch to 0 or side lights, the DRL's come on?
Reading the user manual, DRL should come on when auto is selected?
Appreciate if anyone can advise what I am doing wrong or can try to...
Stuck in traffic this morning, trying to get across Tamar bridge to Cornwall. I usually just drive with lights on auto but being bored decided to check out the lights on the reflection of the van in front. Went straight to main beam all good. Then i went to side lights. All good but have only...
hi all’ looking for a little help .
When auto lights selected clock are illuminated
When side lights are selected clocks are not illuminated
When main lights selected clocks are illuminated
Is this normal or do I have a problem
I have vcds but no idea where to check any help appreciated
Cheers
I have the LED lights on my T6. I've not driven much at night but last night drover down to the Alps. I discovered that the self levelling has levelled my lights to somewhere about tree height. Literally, gturning full beam on illuminates the tops of the tress but doesn't change the road...
